Flappo:
Is led backlighting really that much better than ccl ?
I saw a 7 40 & the 10 46 and thought the 7 had a much more natural looking picture,
the 10 while very bright and sharp looked a bit too technicolor for my tastes
- No, the main advantage of a LED edge-light concept (beeing used in BV10s) is the reduced
thickness of the panel assembly compared to a CCFL or a LED direct backlight (beeing
used in BV 7s)
- Agreed, the picture of a BV10-40 and 7-40 are different because:
"white" from a LED is not exactly the same as "white" delivered by a CCFL -
AND, furthermore, there is a difference in the capabilities to process a picture
between the BeoSystem 3 in a BV7 and the "engine" of the BV10.
beolion:
... every time when I look at the 7-40 in a bit darker room and especially with darker scenes,
then I notice a big difference between the 7-40 and 7-55 ...
A perfect description how local dimming of the 7-55 is working ...
