Latest post 06-20-2011 9:41 PM by BeoNut1. 26 replies.
Page 2 of 2 (27 items) < Previous 1 2
  • 06-20-2011 7:40 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: Beovision 7 Series (32" and 55") Discontinued
    Flappo:
    Is led backlighting really that much better than ccl ?
    I saw a 7 40 & the 10 46 and thought the 7 had a much more natural looking picture,
    the 10 while very bright and sharp looked a bit too technicolor for my tastes
    - No, the main advantage of a LED edge-light concept (beeing used in BV10s) is the reduced
      thickness of the panel assembly compared to a CCFL or a LED direct backlight (beeing
      used in BV 7s)
    - Agreed, the picture of a BV10-40 and 7-40 are different because:
      "white" from a LED is not exactly the same as "white" delivered by a CCFL -
      AND, furthermore, there is a difference in the capabilities to process a picture
      between the BeoSystem 3 in a BV7 and the "engine" of the BV10.
    beolion:
    ... every time when I look at the 7-40 in a bit darker room and especially with darker scenes,
    then I notice a big difference between the 7-40 and 7-55 ...
    A perfect description how local dimming of the 7-55 is working ...
  • 06-20-2011 9:41 PM In reply to
    • BeoNut1
    • Top 500 Contributor
    • Joined on 08-19-2007
    • Mobile, AL (USA)
    • Posts 226
    Any USA Beoworlders know when the BV-7 55" MKII will be available here?
    Mark
    Mark D
