Hello Olly
I definitely agree with your thoughts on this type of amplifier and have been wondering myself how the design can ever work without causing a “thud” on startup. I have used the scope to have a look at the voltage changes and noted the following points.
The DC voltage on the output capacitors builds up very slowly, taking up to 10 seconds to ramp up to 30V. This in itself should not cause a “thud”.
During a one second period immediately after the relay activates, the voltage rises sharply and drops away. This voltage peak is hard to pick up but could be in the range of 5 to 10V before it melts away into the normal DC ramp.
This machine immediately goes to “Standby ON” when the power is applied. Hence the relay is activated while the 60V supply is being established. I thought that the 60V might be causing the problem but then found that the same noise occurred when the unit has been in “Standby OFF” for a period of time. During this time, the 10000uF cap is kept fully charged so it is unlikely to surge when the unit is being switched back to “Standby ON”.
As I said, I have now run out of ideas. Some days it seems that the intensity of the thud is becoming less but I think that is an illusion caused by gradually becoming accustomed to it.
Glad to hear that you are going to try some shims on your beograms – I hope they work as well as these ones have done. A very simple solution isn’t it.
Regards
Geoff
