I have found a source for the RIAA preamplifiers for Bang & Olufsen turntables.
Some of the models are 'prepared' for a RIAA preamplifier. If you need to listen to your wunderful vinyl records and don't own an amplifier with the built in RIAA preamplifier you can now get on.
The RIAA preamplifiers are made as a carbon copy of the original B&O PCB / layout and fits in the B&O turntable. It is very easy to insert the pcb.
I have ordered one for a Beogram 3000 for a customer and all functions very well. The customer is very happy because he doesn’t need an external box and an external power supply for an 3rd party RIAA preamplifier.
The Riaa module can be installed in the following turntables:
BeoGram 3000, BeoGram 3300, BeoGram 3500*, BeoGram 4500*, BeoGram 5005, BeoGram 5500,
BeoGram 6500*, BeoGram 7000*, BeoGram 8500, BeoGram 9000, BeoGram 9500, BeoGram TX
(From the web site of the manufacturer)
This is the link: http://www.mb-el.net/Produkter.html
/Frede
Beolab 5000 - "If another amplifier sounds different then it needs repair!"
