Latest post 02-15-2012 3:20 AM by tuner. 4 replies.
Page 1 of 1 (5 items)
  • 04-22-2011 7:43 AM
    Beocenter 7002 not working
    my father has a Beocenter 7002 which has worked well for about 30 years, except the tape which stopped about 10 years ago.  Now the whole system will not turn on.  There are no lights, sounds, nothing.  B&O say they can't repair it because many of the parts are not available.  I was wondering if there are any repair centres in the UK that  would be able to do something to repair ot or is it a lost cause?
    John
  • 04-23-2011 1:50 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocenter 7002 not working
    John,
    Welcome to Beoworld !
    Of course your Beocenter can be repaired.
    We hear that "parts are no longer available" story too often. B&O can probably
    no longer supply the internal modules etc. but luckily there are people, at least here on Beoworld,
    who can diagnose and repair at component level.
    I'm one of them but I'm in Denmark and I don't dare to think of the shipping cost.
    Instead, I suggest you try contacting Beoworld member nobby, he's in the UK and may be able to help you.
    The fault in your Beocenter could be as simple as a dead capacitor.
    I can supply Tape belts and other parts if needed.
  • 04-23-2011 6:41 AM In reply to
    Martin,
    thanks very much for your reply!  I 'll certainly contact him, it would be nice to get this system running again for him.  How difficult would it be ti replace the belts for the tape deck?  I'm not sure iff that was the problem.  I remember that when you ressed "tp" with a cassette in the drawer, it would try to play, would immediately appear to jam, then stop.  But it has been a long time now.
    Best wishes
    John
  • 04-23-2011 11:20 AM In reply to
    • Dillen
    • Posts 5,008
    Sounds like a belt problem and if they were never replaced, they will most certainly be bad by now.
    Replacing the belts is not as difficult as in many other machines. On a scale from 1 to 10 with 1 being
    the easiest, I would say a 3.
  • 02-15-2012 3:20 AM In reply to
    • tuner
    • Not Ranked
    • Joined on 02-15-2012
    • Posts 1
    hullo I was after belts for a beo centre 7002? can you help?
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
