Latest post 05-14-2011 1:46 PM by Keith Saunders. 1 replies.
Page 1 of 1 (2 items)
  • 04-18-2011 8:31 AM
    • Laursen
    • Not Ranked
    • Joined on 12-30-2010
    • Aarhus, Denmark
    • Posts 17
    Direct control a Samsung BD-C7500
    Does anybody know whether it is possible to direct control a Samsung BD-C7500 Blu-Ray player using the Beo5 remote?
    Is there any sample XML's available, or can I just use the Samsung BDP4600 in the Beo5 XML for direct control.
    I do not want to use the PUC from the TV unless absolutely inavoidable.
    Any help would be much appreciated.
    Beovision 10-40 DVB-T/C/S2, MX5500, BeoSat, MX4000, BeoMedia 1, BeoCord VX7000, BeoSound Ouveture, BeoGram 3500, BeoLab 11, BeoLab 8000, BeoLab 3500, BeoVox CX30, BeoLink 1000, Beo4, Beo5, BeoSound 2, BeoCom 6000, BeoCom 1401, BeoTalk 1100, Beolit 606
  • 05-14-2011 1:46 PM In reply to
    Re: Direct control a Samsung BD-C7500
    I have made you an XML file for the Samsung BD-C7500 player for DIRECT control, but it is not tested, you will need to do that.
    You can download it from HERE
    Regards Keith....
