1st March February 2012
Latest post 06-17-2011 1:20 PM by Electrified. 14 replies.
04-04-2011 6:18 PM
sergi0
- Joined on 03-06-2011
- Posts 99
Hi Folks,
I recently get the new catalog and was very happy to discover that the Beosound 5 will be available without the Beomaster. That is a great new because I do not need it, I already have a NAS (+40TB) with all my media collection on it.
I just have one question... What will be the price of the BS5 Encore? I was not able to find it, neither did I find the time to go the a retailer and ask!
cheers,
sergio
LarsH
- Joined on 06-23-2007
- Uppsala, Sweden
- Posts 42
How will it work?
The software is within the BM5 isn't?
BR/Lars
___________________________________________________________________ BeoVision 7-40 MkIII, BeoSound 5, BeoLab 9, BeoLab 4, BeoVision 3-32, MX 7000, Beo4*3, BeoCom 2, BeoCom 5
Chrisreunion
- Joined on 07-01-2007
- Reunion Island
- Posts 677
BeoSound 5 Encore gains:
- front headphone output, USB input, AUX input
- hidden USB input (for permanent storage on hard-drive)
- Wi-fi B/G/N
What is loses: BeoMaster 5 and the 3 cables that go with it!
Reunion Island is greeting you!
LarsH
- Uppsala, Sweden
- Posts 42
What gains and losses is it in functionality?
Read that it can connect to an iTunes library.
How about the MOTS function, will it work on the external music library?
Will the user interface wiith all functions be there?
The current BM5/BS5 has to use a connector to enable WiFi...
Sounds interesting, is the aim to remove the current BM5/BS5 from the product line?
BR/Lars
Harry2008
- Joined on 11-09-2008
- Netherlands
- Posts 252
Kokane81:Beosound encore is a rip off, uk price of 3000 plus, then u need speakers plus decent hard drive plus won't work with beo 6 for a bit! And that price is per room as it doesn't have ml.
Rather go for Sonos with a pair of B&O spks more flexible systeM.
Seems me a little bit hasty to write this type of conclusions.
Beosound Encore is not available yet, so no formal price point either.
I can hardly believe it will not work with the Beo 6, actually the two way working habbit of the Beo6 will make it a perfect companion. What is your source?
Regarding that you need multiple installations, partly this is the art of the system, to use it you have to touch it :-), on the other hand, I do not know which extensions B&O will deliver to integrate the system in a multi room environment. Just wait a few months...
sjmcguckin
- Joined on 05-28-2010
- Posts 43
I for one don't think Sonos is better. If you want a multi-room system then get a Beosound 5/Beomaster 5.
Electrified
- Joined on 10-05-2009
- Greater Copenhagen, Denmark
- Posts 404
Kokane81:Where u want me to stop?
Sonos: Old type D/A converter maxing out at 16bit (!), 48khz. Volume control is 16bit too, meaning you reduce the bits the lower the volume is. This means a lot with powerful active speakers, as you're seldomly powering them even to half their capability.
BS5: New type D/A converter, 24bit, and can at least run up to 96kHz. Volume control is 24bit (the 16bit files are padded), meaning you will not take a loss when listening at low volumes.
No, for those same reasons, even my lowly Squeezeboxes are superior to Sonos' solution. Even if Sonos is a tad more user friendly when it comes to integration.
I don't like the BS5/BM5 combo, but I'd take that any day over the offering from sonos.
Carolpa
- Joined on 08-15-2008
- Posts 440
Electrified:and can at least run up to 96kHz
it runs up to 192kHz
Electrified
- Posts 404
Carolpa:
Thanks, I was at bit in doubt. I knew it ran at least 96khz, but I wasn't sure it would take 192kHz. It makes the difference even worse (or better, depending on your view).
Page 1 of 1 (15 items)
