Peter,
I do record to the HDD first and then to the DVD and that is the problem!
But having looked on the pages you suggested when I first got the DVD-2, I must have missed the * on page 43, because that says (paraphrased) "when copying from the HDD to DVD you cannot change the mode and it records in the mode originally chosen" in other words, I need to record onto the HDD at the lower quality first and then I should fit more on.
Nothing like being crippled by B&O's "stupid" software :o)
Thanks anyway becuse that helped!
Stoobie
