Latest post 03-23-2011 9:30 AM by scoooby123. 2 replies.
Page 1 of 1 (3 items)
  • 03-22-2011 12:49 PM
    Beomaster 1000 aerial...
    hello all.
    any one know where i can acquire a  Beomaster 1000 aerial... i've tried looking everywhere! can't even find an image? please help... i think the serial name/ number is:
    Bang & Olufsen FM room aerial, type 8902010.
    i just want to complete the set...
    cheers
  • 03-22-2011 1:20 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beomaster 1000 aerial...
    Welcome to Beoworld !
    The old antennas (or arials) are very rare and difficult to find.
    If you find one, expect to pay more for it than you did for the Beomaster.
    I'm almost sure that the number, you refer to, is for a newer model antenna
    as it is mentioned in mid-1990's pricelists etc. and that one may still be available from your dealer.
    No, I think what you look for is this (mounted on a Beomaster 900K):
    PS: Wanted ads should be placed in the Private Wanted section.
  • 03-23-2011 9:30 AM In reply to
    cheers martin.  I want one!!!!
    ok i place an ad in wanted. fingers or perhaps wires crossed!
    thanks again. i bet there was one in the house it came from... just didn't really care at the time... i saved the whole system, amp, speakers, tape deck, turn table from going into the skip... the must have antenna slipped through... if it was there.
    cheers again, good to see what im looking for.
