A common problem with no real cure.
Can sometimes be improved by turning the centre bearing in it's mounting in the sprung chassis. Not guaranteed to work and a proper engineered solution is required.
I have, in the past, sacrificed a low value cosmetically challenged deck with a good bearing by transplanting it's sprung chassis into a high value deck with a loose bearing. Akin to a heart transplant!
