Latest post 03-13-2011 1:13 PM by Medogsfat. 3 replies.
Page 1 of 1 (4 items)
  • 03-13-2011 9:14 AM
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Quick BL2000 question
    Just picked up a Beolab 2000 speaker. Do the frets just pull off - obviously I don't want to force anything & risk damaging them?
    Chris.
  • 03-13-2011 9:31 AM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Re: Quick BL2000 question
    I'm guessing that you've already looked at the service manual but it does state:
    Front Grid: Push the front grid of the speakers upwards and off.
    Maybe the grids are the frets as they are metal on the Bl2000?
    If you think nobody cares, try missing a couple of payments.
  • 03-13-2011 10:03 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    use a credit card in the slot at the bottom of the fret and gently ease upwards, once the gap is wide enough for fingewr nails away you go
    credit card used to avoid fret damage with a more solid tool is screwdriver etc
    bonne dimanche
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 03-13-2011 1:13 PM In reply to
    • Medogsfat
    • Posts 4,045
    Thanks chaps.
    No Steve I didn't read the service manual - the fool that I amEmbarrassed
    Chris.
