Hi Stoobie,
if you want to make custom screens, this is possible. When a level is completely free of buttons it's possible to change the screen type.
A free level can be created by making a button with submenu. You can also move all buttons to the clipboard, but be careful with this, it may crash you configuration. Load old version is a good feature if this happens.
Possible screen type are: 4x3, 4x2, 4x1, 3x3, 3x2, 2x2, and 1x1
If you want to use graphics on the buttons you must keep the size according to this list:
4x3 (92 by 44)
3x3 (92 by 54)
2x2 (140 by 92)
1x1 (255 by 188)
4x1 (255 by 44)
4x2 (140 by 44)
3x2 (92 by 92)
