1st March February 2012
Latest post 03-11-2011 2:58 AM by stotty1111. 19 replies.
03-07-2011 7:39 PM
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
On a BL 4000 i had a blown fuse, Nick in Sheffield send me 5 new ones for free, put in a new fuse and the BL was playing for some 4 Houers. Connected to BS 3000 with powerlink.
Turned of correctly, but next morning it was dead again. One more fuse in, and now it blew emediately.
Now, cross checking with the other BL I found that 1T1 ( Trafo 8013582)has a bad secondary coil fused with F4 (the one that blows), I checked RL1 and bridge rectifier D1 and everything else connected on PCB 1, and the first items on PCB 2, didnt find anything else.
0T1, the main trafo gives me 23.6-24.5 out, with 114-118 coming in on both BLs
Will it be enough to change 1T1 or should I change more, or could there be an other failure somewhere ???
Any comments, help and even a joke is apriciated.
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
burantek
- Joined on 05-04-2007
- SE USA
- Posts 6,214
Søren Mexico:even a joke is apriciated
Why did the BL4000 keep blowing fuses?
It was stuck in a Trafo jam.
Søren Mexico
- Mexico city
- Posts 1,621
burantek:
I would like some help too
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
That was entertaining, Jaff!
Søren, do you mean the primary winding is bad (shorted, or...)? That should be enough to blow the fuse without any other problems present. If the speaker had a bad short somewere else on the low voltage side, I believe it would've burned the rectifier or something.
If you want to be sure, you could of course swap the good transformer from the other speaker into the problem unit and try it. It'll either work or blow the fuse...
Søren Mexico
- Mexico city
- Posts 1,621
tournedos:
Sorry for the confusion, yes its the primary winding, measuring with all plugs disconnected and fuses out, on the good BL, I get 585 ohms on one winding and 604 on the other, on the bad one I get 275 ohms on one winding and no connection on the other (the one connected to F4, the fuse that blows), the bridge rectifier and RL1 shows same readings on both BLs, S1 works without problems (On-Off checked some 20 times)fuses F1, F2 OK, 0T1 gives 23.6 V out with 114 V in, and 24.5 V out with 118 V in, I have the BLs normaly connected to a "no break" with voltage regulation +- 5 %.
Now, where can I get a Trafo ??? B&O here in Mexico only sells equipment and I dont want to leave it for repair, as they are going to change the whole PCB and probably more, and charge alot of green backs for it.
Jaff, waiting for a joke on this one (the 3000s arrived safe to McAllen)
burantek
- SE USA
- Posts 6,214
Søren Mexico:
Mexico... these should work!
Søren Mexico
- Mexico city
- Posts 1,621
Llewelyn:
If it helps I have a fault BL4000 complete PCB which I can send to you for test purposes? (Or to butcher?)
Llewelyn Thats a great offer, I will try to get something in the US or nearer by, but if its not posible I will come back to you, could you check if the STB trafo is ok ??
I just love this forum.
And Jaff, my windings are allready toasted, so toasted tortilla bits wont help
Søren Mexico
- Mexico city
- Posts 1,621
Søren Mexico
- Mexico city
- Posts 1,621
Anybody knows how many mA for the 1T1 trafo ??
stotty1111
- Joined on 12-16-2007
- UK / France - Nth Worcestershire/Finistere
- Posts 924
In a ml mcl converter used as a passive amp i used a similar sized transformer ie as the original with a 12volt 9VA secondary, giving this has worked fine for the last 18 months!
I think the control circircuitry is fairly standard so should work in this app
tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
stotty1111
- Posts 924
tony
Søren Mexico
- Mexico city
- Posts 1,621
stotty1111:
tony
Secondary coil in BL 4000 is 24 V, I've been surfing for print transformer more or less same size, but no such luck, there is a lot of 230V primary out there but 110, 115, 120V nearly nothing, I think I need some 500 mA as the fuses are 650 mA, the space in the speaker is limited.
Most trafos I find is 1 or 2 primary coils and nearly all 2 coil secondary, with 2 coil secondary I will have to build something to get the solder pins to fit to the board.
anybody knows an US supplyer for print transformers, or a B&O dealer that sells spares ???
stotty1111
- Posts 924
you sure its 24 v out? could be 12v out, which smoothed would be about 16.5v then no load situation would boost it/?
alternative would be a 230v unit with 2x 24v out in series to give 48v then with 120 onto the unit about 24 out
t
Søren Mexico
- Mexico city
- Posts 1,621
stotty1111:
t
I'm sure, the repair manual says 23,5 V DC after bridge rectifier, and on the other speaker I have 23.6 V out with no load on the sec. coil, with 110-115V in.
230V/2x24v is a good idea, but space is limited and will have to make connections to the pins from PCB.
As the fuses are 650 mA, which size trafo can I use, 500 mA ???
stotty1111
- Posts 924
ok, so the voltage after rectificartion is 23.5 which would have a smoothing cap in the circuit to give the 23.5 if divided by approx 1.45 this gives a transformer output of around 15v can you find one to fit with that output on the secondary, size may dictate the va figure, and from that you can get the ma output which would then give you a fuse value500ma would probably be ok as the stdby circuitry does not need lots of power
think that makes sense!
salut
t
stotty1111
- Posts 924
a 9va transformer would seem to fit the bill,
9/15=0.6amp=600ma
maybe a 14v secondary to give you your 0.625ma
i think both should work ok!
t
Page 1 of 1 (20 items)
