Latest post 03-07-2011 4:35 PM by solderon29. 3 replies.
Page 1 of 1 (4 items)
  • 03-05-2011 1:37 PM
    • Keith
    • Not Ranked
    • Joined on 03-05-2011
    • Cardiff
    • Posts 2
    BT remote
    Where can I find a list of codes to enable me to operate my B&O tv with a BT remote?  I have tried the BT listed codes of 0104, 0105 and 0182 to no avail.
  • 03-06-2011 11:27 AM In reply to
    Re: BT remote
    I suspect that the BT vision remote will only function with older "pre-bl1ooo" B&O tv's?
    It seems to use the standard 36/38khz transmission rate,so won't work with the higher 455khz that current B&O product utilises?
    You could probably set up a Logitec remote to work both pvr and tv though.
  • 03-07-2011 11:51 AM In reply to
    • Keith
    • Not Ranked
    • Cardiff
    • Posts 2
    Re: BT remote
    If I purchased a generic remote control with transmission frequencies up to 485khz, then that should operate both the TV and STB?
    TIA
    Keith.
  • 03-07-2011 4:35 PM In reply to
    Re: BT remote
    Indeed.The Philips Prestigo and Logitec remotes will def work with current B&O product.It might be prudent to check before buying that they will work with the BT box,as it's quite a recent product.But both devices are learning types too!!
