I have a Beomaster 6000 with a couple of faults, one being a faulty volume control. It started off becoming sticky then over time has got to the stage where it has failed completely.
Tension on the string is fine, and now to adjust volume I have to lift the lid and manually move the string to change the volume which is annoying!
It doesn't work using the remote either!
I have the service manual, and another Beomaster 6000 for parts - I just wondered where the best place to start fault finding would be?
I swapped out the motor control board (board #6) just to try a quick fix but this didn't cure the problem!
The other fault is that the amplifer cuts out and goes into stand by when the volume exceeds around 35-40 on the scale. If anyone has any idea what could be causing this or where I should start looking that would be great!
Any ideas or advice appreciated!
