Latest post 03-10-2011 3:18 PM by MurphyBrooks. 6 replies.
Page 1 of 1 (7 items)
  • 02-27-2011 3:04 PM
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    Bs5 to B9
    Gents,
    I've got the bm5/bs5 connected to a bv9 as the dtv.
    I can get the bm5 screen but cannot control it.
    I've tried it with a 3.5mm cable connected to the control of bv9 and ir of bm5 and with no 3.5 mm cable.
    Any thoughts?
    I'm ready for something new that I actually want to buy!
  • 02-27-2011 3:23 PM In reply to
    Re: Bs5 to B9
    Hello mjmedio,
    I think that bm/bs is cabled with ML to the BV9 ??
    Try to connect the bs/bm as "pc" .....
    it should work ;-)
    Niederrheiner
  • 02-27-2011 5:25 PM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    Re: Bs5 to B9
    I have it connected to my ML network.
    I cannot get any control over it? Does it respond to PC commands over the network ?
  • 02-27-2011 6:16 PM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    Re: Bs5 to B9
    To further the dialogue.
    My bv9 shows the PC as av5 but it is grayed out.
  • 02-27-2011 11:22 PM In reply to
    Re: Bs5 to B9
    Normally you can control it by N.Radio/N.Music over ML
    And it accept PC commands over ML-Networks
    Why is PC grey?? Used by another ??
    Niederrheiner
  • 02-28-2011 1:18 PM In reply to
    Re: Bs5 to B9
    Did you connect it's video via  hdmi ? This will not work ...
    you should connect the BM5 via the VGA input and not via the hdmi.
    The BS3 detects it is a BV9, so it assumes a BM1 is build in in the system, connected via VGA...
    if the ML cable is connected it should work when you select PC
    you do not need a IR input on the BM5
    regards
    nico
  • 03-10-2011 3:18 PM In reply to
    Re: Bs5 to B9
    Sounds like your BV9 has a built in beomedia 1. This needs to be removed or disabled before you can control the BS5
