Latest post 02-22-2011 1:34 AM by tim Reed. 2 replies.
Page 1 of 1 (3 items)
  • 02-22-2011 12:01 AM
    • tim Reed
    • Not Ranked
    • Joined on 02-11-2011
    • san diego ca.
    • Posts 6
    • Silver Member
    beo4 remote contol
    Will the beo4 remote work on older models such as beovision mx5000 . I have found an mx 5000 but no remote. Since this is a tv designed for usa will a uni remote work ?  What about he codes ?Thanks for any assistance Tim
  • 02-22-2011 1:17 AM In reply to
    Re: beo4 remote contol
    The remote is backwards compatible, So it will work!  It would possibly be worth more than the tv, though!!
  • 02-22-2011 1:34 AM In reply to
    • tim Reed
    • Not Ranked
    • san diego ca.
    • Posts 6
    • Silver Member
    Thanks for your reply . Perhaps you could help me with my beovision av5 which I am having problems with getting sound out of the tv. I only paid fifty dollars American so it may be worth saving .Thanks again Tim
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
