Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
I have a Beogram 8000 that has no sound or very faint
sound coming out of the right speaker channel of the main set of speakers. Sound
from the left channel seems normal. I have tried to isolate where the problem
is by checking the following:
1) I
moved the 8000 over to another receiver and had the same result of no sound
from the right channel, while the left was good.
2) I
exchanged cartridges between the 8000 and a Beogram 4002 and played both on the
same stereo system. The right channel sound was missing when using each
cartridge on the 8000. Both cartridges worked fine on the 4002.
3) Hooked
up the 8000 to two different stereo systems. No sound on the right speaker in
either system. The 4002 performed normally on either stereo system.
4) Tested
using two external phono preamps with each turntable to the same receiver. No difference
between the two…the 8000 still had no sound in the right speaker while the 4002
had sound in both speakers.
5) Used
a spare DIN to RCA cable on the 8000 with no difference.
It seems that the problem is within the 8000 unit. I would
appreciate any assistance in identifying possible causes and troubleshooting
the problem.
Thanks in advance.
