Latest post 02-15-2011 6:09 AM by stefan. 1 replies.
Page 1 of 1 (2 items)
  • 02-14-2011 4:29 PM
    • Saxpy
    • Not Ranked
    • Joined on 07-10-2007
    • Stockholm, Sweden
    • Posts 24
    Are there any real differences between different IR-eyes?
    In B&O's ML-guide there are two different connections for external IR-eyes. One that is connected with a 3-lead cable via a 3.5mm connector and one that is connected using a 5-lead cable via a DIN connector.
    What are the extra two wires used for in the latter and is there any difference between different verions of the actual IR-eye.
    The reason for asking is that I have two plasma protected eyes (8087030). One is connected to a Lintronic box and the other one was supposed to be used for an active link kit. Is this possible or do I need a different IR-eye?
    Any help is appreciated.
  • 02-15-2011 6:09 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Are there any real differences between different IR-eyes?
    The IR eyes are the same. They are both for receiving 455 kHz B&O IR signals.
    But the one with the 5 wire cable got additional control like volume up/down, power on/off.
    The 3-wire version is just an IR receiver with 5V-, IR-signal- and ground wire.
    Stefan
