1st March February 2012
Latest post 10-19-2011 1:35 AM by Leslie. 27 replies.
02-14-2011 1:46 PM
musicismoving
- Joined on 03-13-2008
- Posts 12
Beomaster/CD 4500 glass panel replacement
Hi, I will shortly have the answer to the problem of the unavailability of the glass panels for the Beomaster 4500 and the CD4500.
They will be a very very close copy of the originals with all lettering, windows and fonts looking very similar indeed.
They will of course work perfectly unlike certain people who are selling just a piece of blackened glass!!!!! (Anyone can do that)
If you are interested please let me know.
musicismoving@hotmail.com
regards
Barrie
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Re: Beomaster/CD 4500 glass panel replacement
Would like to see some pictures of one fitted in place.
Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
musicismoving
- Posts 12
Hi, I will fingers crossed have the first final example in approx 2 to 3 weeks.
Dillen
- Joined on 02-14-2007
- Copenhagen / Denmark
- Posts 5,008
Sounds interesting indeed ! Do let us know the results.
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
Barrie, I'm interested as well, please keep us informed
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
musicismoving:
Those really are a poor attempt aren't they. I saw one listed at 99p start and that's what it sold for - overpriced IMO. I won't evn start on speaker reclothing kits with double sided adhesive tape.......
Chris.
Leslie
- Netherlands
- Posts 2,201
Medogsfat:
musicismoving:
Chris.
Are you guys referring to somebody on Ebay
Using adhesive ds tape for reclothing works if you are using the right type of tape. I did a lot of CX's and it works perfect. Yesterday I did a Beolab 4 which is quite easy to do using this tape on both sides of the grill.
The front panel is original grey, just reclothed the two side panels in black! Lots of oppurtunities to do things yourself on refurbishing B&O stuff. (sorry, bit of off-topic now)
raybody
- Joined on 03-16-2008
- Posts 10
are you planning to get your panles to opperate the unit like the ones Quality Dream Audio sell on ebay or will they just look the part but not work ?
as i am sure your aware the touch panels will not work (even if you cant see what you are pressing but i am sure you know where the buttons are on your system) through glass unless it has been prepared with a graphite solution to conduct through the glass.
let me know how you are getting on with these as its been a long time since your post.
Leslie
- Netherlands
- Posts 2,201
I bought 3 transparent glas panels, and conductive graphite paint is on its way. So that's a start. Cad drawing has been made. Laser engraving will be the nex step.....
Leslie
- Netherlands
- Posts 2,201
musicismoving:
It's 7 months now
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
Leslie: It's 7 months now
The paint has to dry
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
Leslie
- Netherlands
- Posts 2,201
musicismoving:
Well, at least he came up with something. Let's wait untill the paint has dryed....
Søren Mexico
- Mexico city
- Posts 1,621
Leslie: Well, at least he came up with something. Let's wait untill the paint has dryed....
Totally agree, only joking
Leslie
- Netherlands
- Posts 2,201
Okay, just finished my last 6 panels for the Beomaster 4500.
Posting lots of pictures here is very time consuming since every 4 pictures I have uploaded I get this annoying "Diagnose connection problems" issue!
So just a few here of the results and the rest can be seen on my webalbum for those who are interested!
Just a peek of what I will finish next week
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Leslie: So just a few here of the results and the rest can be seen on my webalbum for those who are interested!
All right! These beat the black glasses by a nautical mile!
Did you consider using some kind of coloured foil for the lighted areas, similar to the display windows? The result with the coloured paint seems a bit uneven at some pictures (number 22). But maybe the the photos just exaggerate it!
Dillen
- Posts 5,008
That's why I admire your work. Wonderful product(s) that will solve many problems. You did it and you can be very proud.
Leslie
- Netherlands
- Posts 2,201
tournedos: Did you consider using some kind of coloured foil for the lighted areas, similar to the display windows?
Yes, I know Mika, have to check why that's happening with the green (glass) paint I've been using. I'm also not satisfied about the displays.
Have been using a sort of sunfoil and I can't manage to get a smooth surface on the glasspanel. Other members advised me to use a sort of spray (Motip) but (I think) that cannot be used on glass. It's more meant for plastic. Will try to improve the quality of these panels though.
@Martin, thank you sir, same as I admire you and lots of others giving their contribution here on this wonderfull forum.
tournedos
- Finland
- Posts 5,808
Leslie: Yes, I know Mika, have to check why that's happening with the green (glass) paint I've been using.
The paint seems rather thick - maybe it would work better if you thin it and then apply several layers? A lot more work unfortunately.
Dunno if another layer of that light dispersing opaque tape on the LED frames would help. Just noticed that I have on my desk a roll of office tape that looks exactly the same! Wonder if it is available in colours? Or if you could colour it with overhead transparency pens or some such, and just leave the glass unpainted...
Leslie
- Netherlands
- Posts 2,201
By the way, it's not my intention to make more of these. It was just a challenge and curiosity if I was able to make a few for my self (eventually 10). Maybe some more for the BG4500 CD. Anyway, it's possible to make them, that's the whole idea
Dennis
- Joined on 02-01-2009
- Denmark
- Posts 172
Leslie:
If it's that product made for darking the rearlights on cars you are talking about, then it can be used on glass as well! I used this with succes to coat the display window on the one side on one of my AV 9000 control centers. It's really just a dark clearcoat.
- Dennis
I was borned with a Beolink 1000 in my hand!
Ever seen a Beomaster 6001? I have one! Look here.
Main system: Beovision AV9000, Beocenter 2300, Beosystem 3500, Beolab Penta MKIII, Beolab 3000, Beogram 6500, Beolink 1000, Beolink 5000, Beolink 7000
Wish list: Beolab 2,
Leslie
- Netherlands
- Posts 2,201
tournedos: The paint seems rather thick
That must be the reason! Oh well, I'm pleased with these and now you can see what the quality is of B&O products (isn't it Graham )
Søren Mexico
- Mexico city
- Posts 1,621
Again Leslie comes up with an impressive piece of work, just to see if it can be done.
Leslie
- Netherlands
- Posts 2,201
tournedos: The result with the coloured paint seems a bit uneven at some pictures (number 22).
Just found out that number 22 was a picture taken from my proto. This is a picture of one of the last 6 I've made.
