I have an Avant and various Beovision 6's throughout the house. We have a Sky HD box and Sky + box. The entire system has been working perfectly for years. However, the Avant has recently stopped controlling the Sky HD box. The IR cable is plugged in (to the Avant) and the Sky + box is controlling through the avant however, the Sky HD box is not responding to the remote on the Avant.
The Sky HD is controllable from the Beovision 6's.
It does appear that the IR cable on the avant is failing or the Avant has lost the settings that work the Sky HD box, it currently set to '40 Pace Sky +'. However, the Sky + is being controlled from the Avant therefore, the IR cable must be doing something!
Very confused and have no idea what I should now try. I have a feeling that calling B&O out will just result in a bill and not necessarily solve the problem!
