Latest post 02-01-2011 2:29 PM by root. 1 replies.
Page 1 of 1 (2 items)
  • 02-01-2011 11:11 AM
    Tool to remove battery from beocom2?
    Hello All, I purchased the replacement battery for beocom2 but have no clue how I can remove the battery cover? Looks like I need a tool once I remove the screws from the magnetic plate and see the other cover holding battery. So frustrating
  • 02-01-2011 2:29 PM In reply to
    • root
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Posts 163
    • Silver Member
    Re: Tool to remove battery from beocom2?
    remove the screws with a torx screwdriver, unplug the cable from the connector, buy a knipex plier for internal rings like this, remove the black plastic part using the plier, shake the phone a bit, voila: the battery comes out.
    Marcel
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
