Latest post 04-02-2011 6:10 PM by guidovangool. 2 replies.
Page 1 of 1 (3 items)
  • 01-25-2011 2:35 PM
    Beocenter 8500 power relay needed
    Hi all,
    After having repaired many faults in the power circuit and replacing the "normal parts" (mute relay, backup battery) the only component left broken is the power relay.
    I haven't seen them being broken a lot, but probably due to a failure in the 7V circuit the relay coil burnt through (or the other way around).
    It's the 4PDT 12 + 2 pins relay (RL1 on PCB60).
    Tried already many sources, but it seems this relay is becoming obsolete / old fashioned etc... Not in stock any more (tried Tyco/Axicom; Farnell; RS components; Siemens and Panasonic).
    So any one here has such a relay by any chance (or a good source/hint?).
    Thanks a lot!
  • 03-03-2011 12:44 PM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Re: Beocenter 8500 power relay needed
    Can you post pictures - with the top/side view, and the bottom pin views?
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 04-02-2011 6:10 PM In reply to
    Found some old stock at the local electronics dealer. Problem solved.
