I'm going to update an earlier post about not being able to get the TV to power on.
After sitting in a climate controlled environment for a few weeks, I decided to try again and happily the tv powered on and gave a a set-clock message as well as a static-y screen. (Re-reading that, I'll trust you know I meant that it was the TV sitting in a climate controlled environment)
Anyway, a good start...so here's the question(s)...do I need a remote to operate the basic functions of the TV (and) does anyone know if the remotes they advertise on ebay as working with a range of B&O tv's (that are not B&O remotes) really work?
Thanks in advance for any advice, g
