chartz:
Dillen:
What is the diameter and thickness of the nylon insert ?
Martin, I can't get it out of the shaft
. But it should be about 1 mm by 10 mm or thereabouts.
Try to drill up the hole to 2.5 Mm, force a 3 Mm screw into the hole and pull.
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
