Latest post 02-12-2011 5:03 AM by chartz. 29 replies.
Page 2 of 2 (30 items) < Previous 1 2
  • 02-10-2011 8:59 PM In reply to
    Re: Beogram 4000 bearing disc replacement
    chartz:
    Dillen:
    What is the diameter and thickness of the nylon insert ?
    Martin, I can't get it out of the shaftAngry. But it should be about 1 mm by 10 mm or thereabouts.
    Try to drill up the hole to 2.5 Mm, force a 3 Mm screw into the hole and pull.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 02-11-2011 4:05 AM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    How is it stuck in Jacques? Force fit or glued? You could use a stick of wood and carefully try knocking it out...?
    Olly.
  • 02-11-2011 10:08 AM In reply to
    • chartz
    • Joined on 07-20-2009
    • Burgundy
    • Posts 984
    • Gold Member
    It just won't go. But anyway, I'll wait till I find a suitable replacement.
    Thanks for the suggestions!
    Jacques
  • 02-11-2011 1:38 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    The Beogram 8000 series has a tiny hole at the bottom of the brass part where a tiny screwdriver
    or similar can be inserted to push the insert upwards.
    I don't know if the Beogram 4000 has the same.
  • 02-12-2011 5:03 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Hi Martin,
    Yes there is a hole at the bottom of my Beogram 8000 shaft. Its bearing is of very high quality and the platter will rotate for AGES when launched by hand! Not so the end of production Beogram 4000 like mine. It is a pretty machine ruined by a poor bearing. It is quite a contrast to the one shown here by Olly! It is noisy. Of course you can't really hear it unless you stick your ear to the plinth, but it is here (motor and belt off, and no, nothing rubs!). I used Mobil One for the bronze insert and teflon grease at the bottom, because an oil bath leaks and my shelf will look like a garage floor!
    No hole at the bottom, no.
    Jacques
