Latest post 01-10-2011 1:59 PM by 8chunk. 2 replies.
Page 1 of 1 (3 items)
  • 01-10-2011 12:05 PM
    • 8chunk
    • Not Ranked
    • Joined on 01-10-2011
    • Posts 2
    How to store change in screen format for Beovision 3
    Hi
    I would like to be able to change the format of the picture on my recently acquired Beovision 3 TV.
    I've read through the manual and have found out how to change it on a "one off basis"... by going to Menu... Setup.... Format...1..2..3
    What I can't seem to do is get the TV to store the new setting for next time.
    What am I doing wrong... or is it ony possible to alter the screen size each time I use the TV?
    Any pointers are more than welcome.
    Thnx in advance
    Richard
  • 01-10-2011 1:37 PM In reply to
    Re: How to store change in screen format for Beovision 3
    Richard,
    A Very Warm Welcome to Beoworld..
    Depending on the transmission the format will automatically set. If you change it using the FORMAT command, that setting is NOT stored for future use, only for the current viewing.
    In other words, if you want to change it, you will have to change it each time you use the TV.
    Regards Keith....
  • 01-10-2011 1:59 PM In reply to
    • 8chunk
    • Not Ranked
    • Posts 2
    Thnx for you welcome Keith and your advice
