Hi there, need some help please
I would appreciate some help with fixing the turntable lid on my 7002 center. Im basically trying to get the lid to stay up when I open it as it just collapses every time.
Ive taken the 3 screws out at the back to try and sort it out as it seems it should be simple but if it is then it hasnt dawned on me yet!
I think that somebody has tried to fix it before as the wire has been out and probably misshapped before being put back in the wrong way
around. Whats the procedure people? Thanking you in advance....
