1st March February 2012
Latest post 01-14-2011 10:13 PM by TripEnglish. 13 replies.
01-03-2011 3:33 PM
Chris
- Joined on 03-19-2010
- Corbridge, UK
- Posts 353
Connecting my Iphone to a Beosound 3
I'm looking at a way of listening to my Iphone with its radio app, but through a Beosound 3 with its SD card slot(it has no mic)!
Is there a cable, be it Apple or USB that can then directly connect into a SD card slot to play music to the player?
I have been looking high and low and cannot find a solution so any help appreciated. I don't want a full blown system just something i can personally listen to at home and away. Basically turning a Beosound 3 into an Iphone speaker. I don't listen to FM at all now so that buggers everything up!
Regards
A Beovision 10-40 in black and red fret on order, Beo4, Beo6, many A8's, a pair of white and yellow Form 2's, Beocom 4, 28 inch Avant RF DVD, Apple TV and a wife that loves this stuff as much as i do!
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Re: Connecting my Iphone to a Beosound 3
Pretty sure that no one makes a cable like the one you mention. Think there has been a thread before that mentioned the same thing. Something that would has a jack plug at one end, and the other fits into the SD slot. It would then covert the music on the fly as it were. You could try one of those FM transmitters that plug into the headphone socket. They have several frequency settings. You choose the one you want, then tune the BS3 to the frequency.
Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Stan
- Joined on 04-17-2007
- Posts 593
I've used one of those FM transmitter things so my kids could play their ipods through a BS3. In the US, it's called an iTrip, and it plugs into the wide slot on the iPod, and is powered by the iPod. I recall there being some discussion about different laws around the world with respect to home FM transmitters. This works OK as long as there's open frequencies... and the flat top of the BS3 makes a nice spot to lay down your iPod.
Stan
Heribert
- Joined on 08-06-2009
- Austria
- Posts 592
What about a wifi enabled SD Card? Gould this be an Option? Annone tried?
BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 / Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
Chris
- Corbridge, UK
- Posts 353
Some great ideas, thank you.
I think i'll try the FM tramsmitter
Craig
- Posts 4,855
The one that I saw was made by Belkin. It was powered by one or two AA batteries.
Craig
TripEnglish
- Joined on 10-27-2007
- America
- Posts 1,595
Putting a headphone jack instead of an Aux input on this thing is among the stupidest decisions ever. And I mean in the world, ever. Not just in B&O products. It will go down in history.
There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
Vienna
- Joined on 08-15-2008
- make an educated guess
- Posts 712
chris:
Basically turning a Beosound 3 into an Iphone speaker. I don't listen to FM at all ...
... you're not using any of the key features of your BSd 3 - simply sell it and buy either a BeoSound 8 or a pair of BeoLab 4-PC + an adapter cable to connect your iPod/Phone/Pad
Chris
- Corbridge, UK
- Posts 353
An FM transmitter for £10, or a Beosound 8 for £800
soundproof
- Joined on 04-16-2007
- Posts 2,340
Imagine if the BeoSound 3 had this connection panel. It's from the "comparable" Audio Pro Porto, which came out at the same time as the BS3, but which also came with an iPod dock and a remote control. Sometimes, B&O deselection could be served by some reselection:
I suspect the S-Video port is due to Audio Pro's designer having an old video camera he liked to hook up when showing home movies ...
But two Line-In and a Sub out is not bad.
Chris
- Corbridge, UK
- Posts 353
Its so frustrating, as this is hardly new technology.
Thanks for posting
Chris
- Corbridge, UK
- Posts 353
I have sorted this problem out very easily by buying an Iphone fm transmitter for £5 from Amazon. Tunein radio app, select station, attach transmitter, tune in Beosound 3 to transmitter frequency and hey presto a Beosound 3 with 5000 stations!
TripEnglish
- America
- Posts 1,595
They also seem to have forgotten how attractive wood grain is when applied to sleek modern products.
Page 1 of 1 (14 items)
