Hello all
I am going to get a sky engineer or a independent installer to put up a sky dish on my new house with an octo LNB.
I will run the cables myself as i want to instil the in the floor upstairs.
What cable do i need? I keep seeing wt100 twin, CT100 or RG6
the dish will be at the back of the house and the lounge where two feeds will be is right at the front of the house. The distance is 40+ foot at the longest point so WT100 is only recommended for 40feet if I'm correct.
I will also be instlling some CCTV camera's, what coax cable can i use for this? If the same cable will work then i can buy a reel, any help you can give will be great.
Cheers
Beovision 7 MKIV (Blu Ray)
Beolab 9
Beolab 6000
Beo 4
Beocenter 9300
Apple TV
SKY HD
Optoma HD65 Projector
Lintronic TT455-RT-238
Beovision 3 MKII
