improvements and new features in software 1.61a
New features
Possibility of running up to 4 different device drivers of any kind at the same time.
  improvements
  1. After a period of normal operation, the commands from MLGW starts acting on different televisions than originally programmed
  2. If using a Custom String with the value \00, the string will be truncated from this value at power dropout and after reload from file
  3. If Lutron HomeWorks is disconnected from and reconnected to the mains, MLGW will no longer detect events in the Lutron system
  4. MLGW serial number set to 00000000 after downgrading software from V1.50
  5. MLGW locks up when using the button Upload text file
  6. The television continues to adjust volume up after releasing button on iPhone
  7. MLGW resets when receiving multiple commands from RS232 .
									    BeoVision 4 - 50 HD -  Beo5 - Beolab 5 - Beolab 7-1 - Beolab 6000 .
