Some new info: I was wondering if this could be an electronics issue, since the FF, PLAY, and REW keys do not work at all, only TAPE --
I started the deck with no tape in the well. It will run for about 10-16 seconds then stops.
If I started it again and pressed on the tape sensor switch (middle one, angle shaped, tells the unit that a tape is loaded) the deck would then stop within a second or two.
The unit basically wants to run with no tape in it, but *not* run with a tape in it... Is there some "control board" thing that could have gone bad? The unit is from around 1996, and the tape unit has only 2-3 hours on it, max.
