Dear all
Happy holidays to you all!
Some while ago I connected my Samsung H360R decoder to the BV7-32 MKIII (software AP 7.6 & IOP 22.0) via YPbPr to get "HD-image". Works fine.
Also tried to get digital sound - doesn't work. I installed a converter to overcome optical output at the decoder and coax input at the BV7. Decoder and converter function OK (check both with a DAT recorder with both optical and coax input). Set audio settings to specific entry in the menu. Nothing!
Anybody an idea how to get digital sound into the BV7?
MP
