Latest post 12-22-2010 11:44 AM by Spiros. 7 replies.
Page 1 of 1 (8 items)
  • 12-22-2010 8:15 AM
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Compatibility of Terminal 3000
    Hi all, Does anybody know if the Terminal 3000 is compatible with the Beomaster 5000 (Terminal 5000)? I sourced a couple of 3000 but not a 5000 and wonder if I could control the Beosystem 5000 with this since the Terminal 5000 is quite rare to find this time.
    Best regards
    Spiros
  • 12-22-2010 8:48 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Compatibility of Terminal 3000
    You can't.
    The Beomaster 5000 uses unique coding that only the Terminal 5000 and MCP5000 will provide.
  • 12-22-2010 9:01 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Hello Martin, That was the answer I was hopping not to hear!!! Many thanks for the information. Best regards Spiros
    Best regards
    Spiros
  • 12-22-2010 9:40 AM In reply to
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 12-22-2010 9:47 AM In reply to
    • Dillen
    • Posts 5,008
    Thanks Søren, but that one is a Beocenter Terminal for the Beocenter 7007/7700.
    It will NOT work with the Beomaster 5000.
  • 12-22-2010 9:51 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Hi Soren, Many thanks for the link. And Martin also for the information!!!! Best regards to both of you. Spiros
    Best regards
    Spiros
  • 12-22-2010 10:26 AM In reply to
    Sorry Spiros, frigging Bay hustlersErm
  • 12-22-2010 11:44 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    No problem Soren. I thank you for instantly checking!!!
    Best regards
    Spiros
