Latest post 12-22-2010 10:14 AM by Opman. 3 replies.
Page 1 of 1 (4 items)
  • 12-21-2010 12:32 PM
    Problems connecting Beotalk 1100
    This is my first time on the forum so forgive me if I've posted in the wrong place. I've been given a Beotalk 1100 to go with my Beocom 6000. The phone is just the basic version with out the PSTN station. Now I can get the Beotalk to work at all. The display stays lit and it shows the sign of a little phone. The little phone symbol tells me that either the Beotalk is unplugged or the line is busy if I follow the manual. The beotalk have been checked over by my local B&O dealer and should be fine. The thing is that the plug is in and that the line is not busy. What am I missing. Do I need the PSTN station, am I connecting the two wrongly. Hopefully some one on the forum can help me as I'm very confused.
    All the best,
    Tom
  • 12-21-2010 7:03 PM In reply to
    Re: Problems connecting Beotalk 1100
    Hi, and welcome to Beoworld!!
    The connections for your Beotalk should be as follows (other Beoworlders please correct me if I've missed something):
    Power socket from wall to 3 way splitter
    Phone socket to 3 way splitter
    Beotalk to 3 way splitter
    Then just follow the manual to set it up!
    My B&O: 2009 Catalogue and Pricelist
  • 12-22-2010 5:14 AM In reply to
    Juxst to add to  jldmelb, the Beotalk must be connected to the primary phone socket and not to a secondary socket.
    You have to use the B&O splitter (others will not be wired correctly internally.)
    Check for loose connections and use elastic bands over the splitter connections if anything seems loose.
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 12-22-2010 10:14 AM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    The BeoTalk 1100 & BeoCom6000 are two seperate products and can be used independently or together on the same line.
    The BeoTalk 1100 can operate even if you don't have a phone connected, however your BeoCom6000 will NOT operate without a PSTN.
    Opman
