Latest post 12-20-2010 2:35 AM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 12-18-2010 5:58 PM
    Beocenter Terminal Remote (won't operate Beocenter 7700)
    Hi i bought a Beocenter Terminal Remote on ebay the guy said it works and it appears to operate the green light flashes for each command but won't run on the Beocenter 7700 that i just bought also. i got them  from 2 differnt  people any thoughts on this? the beocenter works fine manualy and yes the remote switch underneith the beocenter is set to on. Does the remote have to be mated to the beocenter in some way that i don't know to operate?.                 Thanks   Roger
  • 12-19-2010 3:58 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocenter Terminal Remote (won't operate Beocenter 7700)
    No remotes with green LED's will fit the Beocenter 7700.
    Those will be Terminal 3000, 3300 or 5000's and meant for their respective systems.
    You will need the Master Control Panel 7700 or a Beocenter Terminal of the
    type with the same type of black buttons.
  • 12-19-2010 9:38 PM In reply to
    I got it fixed it this is the one i bought in the below link.  i put in to weak a batteries. Its advertised as the correct one .  as for the belts i'll need 7700 Cassete/Phono, Beocord  8000, Beogram 8000 tone arm let me know the info on these Thanks Roger
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rt=nc&nma=true&item=170574507598&si=Ui4wy5rZUU%252FTfKE6%252BIIbA9y5h8Y%253D&viewitem=&sspagename=STRK%3AMEWAX%3AIT
  • 12-20-2010 2:35 AM In reply to
    • Dillen
    • Posts 5,008
    Yes, that's the correct remote.
    You have a PM regarding belts.
