Latest post 12-15-2010 4:22 PM by c_hristian. 3 replies.
Page 1 of 1 (4 items)
  • 12-13-2010 8:14 AM
    Beolab 8000 replace tweeter
    I have a blown tweeter i one off my beolab 8000, anyone changed it by there own ? is it possible to replace fairly easy ?
    Regards, Christian
  • 12-13-2010 8:35 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: Beolab 8000 replace tweeter
    replacing the tweeter will only be half of the job - different versions of the tweeter have been used over
    the last 20 years - recalibrating of the croosover will very likely be necessary
  • 12-13-2010 6:20 PM In reply to
    I have replaced both on a pair of 8000 and on a pair of 6000.
    Both sounds lovely (as far as I can hear) afterwards. (The 8000 got new and the 6000 got a pair of tweeters from a broken MX7000)
    Try do it your self first. If your not satisfied, hand it in to the pro's
  • 12-15-2010 4:22 PM In reply to
    B&Ola
    Thx for the reply ! I wil give it at go..
    Just out of curiosity, does beolab 8000 and 6000 have the same tweeter ?
