Latest post 12-15-2010 4:49 AM by Stonk. 5 replies.
Page 1 of 1 (6 items)
  • 12-11-2010 2:11 PM
    • htiek
    • Not Ranked
    • Joined on 12-11-2010
    • Posts 2
    LX5500
    Hello,
    My brother has just purhasesd a LX5500 from ebay to replace the same model that finaly gave up the ghost. It came with the rather nice heavy die-cast remote.
    However no matter what I do i cannot get the TV to accept an input on scart 1. Scart 2 works fine with the matching VHS recorder and from my investigation it looks as if pressing SHIFT + TV should give access to scart 2 and SHIFT + TEXT allows some form of scart setup.
    However SHIFT + ANY BUTTON does absolutlty nothing.
    Any advice would be gratefully received.
    Thanks htiek
  • 12-11-2010 2:18 PM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    Re: LX5500
    You're on it. Use shift text to enter the menu. Use the arrows to assign scart 1 to wanted input (sat etc.)
  • 12-12-2010 5:49 AM In reply to
    Re: LX5500
    It's possible, that S-VHS input is activated.
    Its a toggle function and stored for every output device, Shift-9.
    Configure it for V-Tape1 (just press VTAPE) and V-Tape2 (Shift-VTAPE).
    Or use SAT instead of VTAPE2. SAT is available if no internal LM-Sat receiver is installed.
  • 12-14-2010 5:21 AM In reply to
    • htiek
    • Not Ranked
    • Posts 2
    Re: LX5500
    Thank you both for your help, I have managed to configure scart 1 as Sat. and the DVD player
    now works with that input.
    Further advice would be appreciated, the MUTE does not work, VOL UP/DOWN is ok
    any ideas?
  • 12-15-2010 3:57 AM In reply to
    Re: LX5500
    You could try a different remote control - sometimes the buttons can stop working. Check this only if you don't see the confirmatory sign which should be displayed on the screen when you press the button.
    David
  • 12-15-2010 4:49 AM In reply to
    • Stonk
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Re: LX5500
    You can test the remote's buttons by using your camera phone or digital camera as shown HERE Smile
    If you think nobody cares, try missing a couple of payments.
