Need help, just updatd to the latest beo4 with navigation wheel. PUC is version 2 and it works fine. but now it does not work with my Beo5. what to do???
Blame google translate for my bad English
My Bang & Olufsen.
Best regards
Spiros
Using Config Tool 3.87 you just change from "No navigation button" to "Navigation button Mode 1". You will find it in section "Choose products". Click on your videomaster (BV7 ?) and the settings menu will display: Stand - Modules - Sources - Navigation buttons...
Stefan
