Latest post 11-30-2010 3:34 PM by beojeff. 6 replies.
Page 1 of 1 (7 items)
  • 11-29-2010 11:22 AM
    keyring
    hi guys
    help needed
    i have a beovision 10 with sky hd, to turn tv on with beo4 i press  vmem and for dvd press dvd
    my question in this when i use my new b o keyring press audio radio starts no problem, when i press video tv switches on but screen shows tv in the top of the screen which in not been used. how ca i programme it to turn tv on with v mem or do i need engineer to reprogramme
    malcolm welborn
  • 11-29-2010 12:17 PM In reply to
    Re: keyring
    The straight answer is that you cannot. However I thought you could change the BV10 so that TV worked the digital tuner by turning off the analogue. If that is the case, it should work.
  • 11-30-2010 1:44 AM In reply to
    • Bieele
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Netherlands
    • Posts 339
    Re: keyring
    That's correct, you can turn of the analog BV10 tuner and assign the TV button to another source (digital tuner). I have done the same, works fine with the keyring.
    Bieele
    Heej zuij der alles veur gaeve En heej zaet ze mogen ut hebbe van meej
  • 11-30-2010 4:30 AM In reply to
    Re: keyring
    many thanks for your replies
    will re assign
    malcolm welborn
  • 11-30-2010 8:29 AM In reply to
    Re: keyring
    It would be so nice if B&O would make a new keyring with a micro-usb port that could be connected to one's computer to change the settings.
  • 11-30-2010 8:34 AM In reply to
    Re: keyring
    I suppose so. I must confess that my keyring has now had a flat battery for 3 years and I have not bothered replacing it - it is just a nice key fob!
  • 11-30-2010 3:34 PM In reply to
    Re: keyring
    Doctor:
    Indeed. I have the original model, which was horribly prone to running the battery down by having the buttons so easy to press while in one's pocket. The new design improved on this. I keep hoping B&O will offer a more flexible solution (e.g., being able to replace "radio" with "cd" or "n.music") before I replace mine.
