QuickTime 7 Pro will do it, just go Edit -> select all on the first video, Edit -> Copy.
New File, Edit -> Paste, then do the same with the second video, pasting at the end of the first video.
You can re-encode in a different format, or sometimes you can select pass-through depending on your video codecs (the ideal solution, no re-encoding is needed).
Cheers,
Alex
