Latest post 11-22-2010 6:31 AM by turbo959. 2 replies.
Page 1 of 1 (3 items)
  • 11-21-2010 7:49 PM
    B&O 1800 turntable problem
    Hello all
    this is my first post,as I am new to these turntables.
    I have a 1800 & 3400
    The 1800 works as it should till the needle hits the record, then it just has a humming niose, I took the cartrige to a friend with an 1800, and it worked perfect. The cartridge is a mmc5,I did notice the switch on the bottom of turntable, and moved it to the mmc5 position, still same outcome. Keep in mind I hooked another turntable up, and worked fine, thus eliminating the stereo sorce. would love any advice.
    Thanks in advance
  • 11-22-2010 1:49 AM In reply to
    Re: B&O 1800 turntable problem
    Check the connections. If using a DIN plug, the wires may be loose inside. There is a muting circuit so I suppose that this might be faulty but I would suspect the connections first.
  • 11-22-2010 6:31 AM In reply to
    Thank you, I will check all connections,Mark
