Latest post 11-22-2010 3:44 AM by warren. 5 replies.
Page 1 of 1 (6 items)
  • 11-20-2010 3:35 PM
    Link room audio problem
    Hi. I have just installed a beovision 8 in the bedroom and having issues with the masterlink configuration...
    The lounge has a Beovision 7 32" and sky hd (connected via scart and component) with a beovision 8 32" in the bedroom. Masterlink and coaxial cable has been connected...
    The bv8 is set to option 6 and although selecting L-DTV brings up the sky picture there is no sound. If I then choose L-AV-DTV sound is received via masterlink
    Any ideas what I might be doing wrong?
    Thanks in advance
    Warren
  • 11-20-2010 4:38 PM In reply to
    Re: Link room audio problem
    on some of the Bv8 the sound settings were set to BG and not pal, I think the option is under the link freq menu on the Bv8
  • 11-21-2010 6:24 AM In reply to
    Thanks will have a look when I get home tonight...
  • 11-21-2010 9:02 AM In reply to
    Just use DTV in the linkroom.
    AV-DTV gives you the sound from the DTV in the mainroom.
    Link DTV is used when DTV is already used in te linkroom with another source.
    DTV gives you the both sound and video from the the mainroom (but only when you haven't  used DTV for another source/connector in the linkroom). That's why option 6 is used, if it doesn't exist in the linkroom, it uses the mainroom source.
    When you have sound but no video after using DTV, then check your linkfrequency.
  • 11-21-2010 11:46 AM In reply to
    Thanks Beobuddy. I have to use link dtv as the bv8 has a dvb module fitted which I believe is hard wired to the local dtv selection
  • 11-22-2010 3:44 AM In reply to
    Had a look last night and it was infact the RF modulator setting mentioned by Kokane81
    Changed it to "I" from "B/G" and it worked...
    Thanks All....
