Hi everyone,
In my living room I have lighting with Lutron Radio Ra 2 with a keypad with IR eye that allows me to control the scenes with the Beo5. Everything works great the only problem is that the IR eye range of the Lutron keypad is a little limited and I have to point the beo 5 very precisely to it and withing certain range otherwise it don't work.
But any chance anyone have a similar setup and use like a IR extender or aditional IR eye. I am a little confused. I read about Lintronic but it seems that is like too much since it does everything like convert codes, projectors, third party products, etc. which I don't need since as I said everything is programmed in the beo 5 and works just fine.
Thank you for your help!
