1st March February 2012
Latest post 12-05-2010 12:27 PM by Søren Hammer. 18 replies.
j0hnbarker
- Joined on 04-16-2007
- LS28/GB
- Posts 2,002
Re: Best MMC Tangential, after the 8002?
Agent00soul:
Not with the MMC2 he won't.
Try looking for an 8002. I have one and it is great, but the build quality is not in the same league as the 4000 series of decks. Either way, a good 4000 or 8002 are going to cost $$$ £££ so you might as well get the deck you want and wait for a good 8002 to come along :)
kimberley
- Joined on 04-21-2007
- London, U.K.
- Posts 40
I have both an 8002 & a 6002 & I struggle to tell them apart when listening. The 6002 is less good cosmetically (though the 8002 is quite smart).
Don't know where in the world you are, but I might be prepared to part with one of them... my wife would be delighted if I did!
Adam K, London, UK.
dbxdx5
- Joined on 06-09-2009
- Posts 65
I'd definitely consider a 6002, but I see those almost as rarely as I see 8002s! What would be people's next picks after the 8002 and 6002? Again, this is for MMC carts.
Adam, I'm in the U.S. Might be too far to safely ship a turntable?
kimberley
- London, U.K.
- Posts 40
I feel that once equipment is packed it doesn't matter whether it's going round the block or round the world, the couriers can find the weak points!
The longer the distance, the more trans-shipments & agencies involved, of course and the greater the chance of the parcel being left in the rain! (I sent a cartridge to Germany recently with a friend who delivered it to a local courier... they dropped it in the snow and RAN OVER it in their own car park within the hour!)
Two problems with my turntables: I don't have original packaging (not insurmountable) but more importantly, the voltage and mains frequency would be wrong for the US. I believe that the drive for the 8002 is frequency-dependant, so a simple transformer wouldn't do the trick.
Sorry!
j0hnbarker
- LS28/GB
- Posts 2,002
Short answer is that the 8002 is the best deck for MMC carts. The 5005 series or any of its tangential derrivatives cannot match the 8002. I have owned them both, and I let the 5005 go and have slept soundly ever since ;)
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
Any tangential after the 8002 (3000 up to 7000) are pretty much the same basic deck, some have RIAA fitted & some don't. Everything else is purely cosmetic.
Chris.
Step1
- Joined on 07-06-2008
- Manchester
- Posts 961
I don't think there is an easy answer, except be prepared to pay the asking price for one that does eventually come along. Either that or pay for a knackered one and get a kit off Martin.
Personally if I was in your position, I would consider one of the later decks if it was that tough to find the one you want - I am sure they are not that much worse in the sound department!
Another option - sell your MMC cart and buy a 4000 series deck? I think they look a lot nicer for one and apparently sound the same, if not better? Just not micro controlled so not as clever and no datalink. Better build though.
esmith5500
- Joined on 11-13-2010
- Posts 2
One alternative is to get one of the later radial decks ,all those later tangential turntables 5005,3000,7000 etc are highly overrated. The later beogram radial decks however are vastly underrated the rx, rx-2 1800, 2000, 5000 are built like a proper turntables and have a better tonearm and are more reliable. They were just never as popular because everyone liked the look of the tangential decks.
Erik
dbxdx5
- Posts 65
Well, I went ahead and bought an 8002 off of ebay! It arrived the other day, and so far so good: Cosmetically, it's a 9 out of 10, and everything powers up fine. Only catch is that I still haven't listened to it because I don't have a 7-pin to RCA cable. I'd like to either make one myself or have someone do it for me. Is there a diagram showing which pin carries which signal? Thanks.
Matt
dbxdx5
- Posts 65
Thanks, though I'd like to make my own or have a cable company I've used before make me a custom cable, which is why I need to know what the pin assignments are.
Doctor
- Joined on 09-14-2010
- Posts 555
No problem - look here for all sorts of wiring diagrams - and more!
Søren Hammer
- Joined on 01-07-2008
- Esbjerg/Denmark
- Posts 554
kimberley:
Sorry!
The Beogram 8000 series works with a quartz controlled computer, not mains frequency
I would definitely get an 8000 or 8002 for your MMC2.
-Søren
Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
Doctor
- Posts 555
Small addition - the 8000 of course uses the MMC20CL cartridge.
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Oh *looks at Beogram 8000 in storage*
You're right
Page 1 of 1 (19 items)
