Latest post 11-11-2010 8:57 AM by tournedos. 1 replies.
Page 1 of 1 (2 items)
  • 11-11-2010 8:20 AM
    • oleiso
    • Not Ranked
    • Joined on 11-11-2010
    • Posts 1
    Beovision MX2000 remote control
    Which remote control can I use for the Beovision MX2000 besides the video terminal?
    Or is there any way I manualle can put it on the AV-channel?
    Thanks.
  • 11-11-2010 8:57 AM In reply to
    Re: Beovision MX2000 remote control
    The only remote that works is the old Video Terminal ("Mars bar").
    If your source has a SCART, just use a fully connected cable and you're done. The MX2000 honors the SCART control signal (pin 8) and will switch to the AV input automatically regardless of what program it was on before.
    Alternatively, switch it to program number 0. I don't have my MX here so I could try, but I think you unfortunately need the remote for that.
    -mika
