Latest post 11-29-2010 11:16 AM by Tim. 6 replies.
Page 1 of 1 (7 items)
  • 10-28-2010 11:34 AM
    BV7- 40 MKII and new Apple TV
    Hello All,
    I need a bit of help here! I am thinking of buying the new Apple TV to connect to my BV7-40 but all the HDMI sockets have been allocated to STB and DVD
    I am now asking if it is possible to get a VGA to HDMI converter for this set up and use SPDIF for sound? as anyone tried this? I dont want to go through the hassle of HDMI expander and incuring extra costs!
    thanks,
    John..
  • 10-28-2010 1:55 PM In reply to
    • Tim
    • Top 500 Contributor
    • Joined on 01-07-2008
    • Germany
    • Posts 114
    Re: BV7- 40 MKII and new Apple TV
    VGA to HDMI prabably wont work, because the new Apple TV only has Digital out (HDMI + Toslink)
    I use an HDMI to DVI cable on my Beovision 7-32 (It needs to support HDCP-Encryption) and the picture ist great.
    In addition you will need a Optical to Coaxial Converter (will cost you approx 10 EUR) to get the sound into your BV7-40.
    Depending on the age of your TV, you will need a software update too.
  • 10-30-2010 11:19 AM In reply to
    Hi
    Have you thought about using the component inputs. This does hi def and sound, I use it for PS3. Unfortunately you cannot then see this anywhere linked throughout the house.
    Brian.
  • 10-30-2010 11:52 AM In reply to
    New Apple Tv lacks the component output. Just has HDMI. One reason I went for the old version.
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 10-30-2010 2:54 PM In reply to
    Yes, that is the issue im facing! i might have to go for the old ATV..
    Thanks all for your reply
  • 10-31-2010 2:10 AM In reply to
    Happily using HDMI from my 2nd generation ATV to my BV8 ... my issue is not enough HDMIs !
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 11-29-2010 11:16 AM In reply to
    • Tim
    • Germany
    • Posts 114
    Germans beware!
    B&O Service technicians just left the house - after trying to update my BV 7-32 Mark 2.
    It is  not possible to update the german Version!
    Please follow the thread here:
    http://forum.beoworld.org/forums/p/33501/302784.aspx#302784
