Latest post 10-22-2010 4:05 PM by Blackrix. 13 replies.
Page 1 of 1 (14 items)
  • 10-21-2010 4:59 PM
    Beolink 1611 & 1614 converters
    Both units have the same connectors (ML at one side, PL and Audio Aux on the other. What's the difference between those two?
    Regards, Leslie
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 10-22-2010 2:50 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Re: Beolink 1611 & 1614 converters
    Software/hardware programming(?) - I have both, and there seems to be no difference in operation with my useages!
    Member Vienna may be able to help!
    Tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 10-22-2010 3:03 AM In reply to
    Thank you Tony, let's wait if Vienna has the answer!
  • 10-22-2010 5:31 AM In reply to
    Is the 1615 converter the same as these two as well?
    I believe the 1610 is for AV9000 connectivity only?
    Train Hard - Run Fast - Hit to Kill!!!
  • 10-22-2010 5:36 AM In reply to
    I wonder how many Beolink converters exist and if someone has a list what they do?
  • 10-22-2010 7:43 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    stotty1111:
    Tony
    Hello Tony, here is a short overview:
    BeoLink Converter:
    EU 1613 - introduced 1995
    EU 1611 - introduced 1997 (recent SW version is 1.3)
    US 1614 - introduced 1995
    US 1612 - introduced 1997
    ML/AAL converter with internal power supply and stand-by switching.
    For connection between ML and 7-pin Din AAL (Audio Aux Link = DataLink)
    audio and video products.
    Special (BeoLink) Converter versions:
    Type 1610 - Audio kit AV 9000 MKII
    Type 1615 - No Power Link mounted
    PS: Tony - sorry, no news about A.Aux compatibility
  • 10-22-2010 2:07 PM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Very useful list. One question. I'm discussing on buying a Beomaster 7000 because as far as I could remember it can be linked on current links using the BL 1611. Can you please specify if this is correct? Many thanks in advance.
    Best regards
    Spiros
  • 10-22-2010 2:19 PM In reply to
    Spiros:
    Yes. It should work fine.
    You will need a 7PIN DIN (Male - Male) and a PowerLink cable.
    • B&o bottle opener
  • 10-22-2010 2:20 PM In reply to
    The difference between the 1611 and 1614 converter is the following. With a T1611 converter an ML link product can be connected to a non ML-product (for instance a BeoLab 2000 to a BeoCenter 2300). This is not possible with a T1614 converter. When a linksystem has to be connected to a 1614 converter, there always has to be an ML master product in the mainroom. So the earlier mentioned setup (BeoLab 2000 and BeoCenter 2300) will not work with a T1614, but when for instance an Avant is also connected as a master TV, it will work.
    T1615 is a BeoLink Video, for connecting an AAL television (for instance an MX7000) to an ML system in a linkroom. T1616 is a BeoLink Active for connecting active speakers to an ML system in a linkroom. T1636 is a BeoLink Active, like a T1616, but the T1636 has an extra input for connecting BeoLink PC-office as a local source.
  • 10-22-2010 2:31 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    burantek:
    Spiros:
    Many thanks Jeff. Always on duty!!!!
    Best regards
    Spiros
  • 10-22-2010 2:47 PM In reply to
    Spiros,
    Just to clarify (and I should have asked)... If speakers are attached to the BM7000 (OPT1) -then you do NOT need the PL cable. If there are no speakers attached (OPT0) then you will need the PL cable.
    If a cable is needed -it does NOT have to be the fully pinned variant. However, should you be using a display speaker -a fully pinned PL cable would be in order... BUT (and I don't know the correct answer) the BeoLink converter may not pass display data along???
    • B&o bottle opener
  • 10-22-2010 2:53 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Hi Jeff, It's going to be linked and most probably in A.Option 5 or 6. Certain Speakers will be of course attached on it so......... I think I need the full cabling/pinning on them.
    Best regards
    Spiros
  • 10-22-2010 3:19 PM In reply to
    Thank you all for this usefull info, special thanks to Blackrix & Vienna for their additional detailed iinformationYes -  thumbs up
  • 10-22-2010 4:05 PM In reply to
    You're welcome, but I think "Graag gedaan" will also do the trickWink
