        1st March February 2012
	    Latest post 10-21-2010 4:17 AM by Sigmund . 13 replies.
								    |  10-18-2010 3:04 PM |  |
									                 bayerischeJoined on 12-11-2007Helsinki, FinlandPosts 3,593 |
										    Apple express, better sound with a DA converter, but which one?
										    Hi guys,   My trusty BS9000 is wonderful for CD's, but since buying music on iTunes is so darn easy, I would like the option of good sound trough the "air". I have a Airport express that is connected via rca cables directly to the aux in on my BS9000, the sound is awful!  How to get a better sounding system? I don't want any cables from the computer to the BS9000, it should be wireless to the express/or like, and from then onto the BS9000.   Thanks Andreas -Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2     |  |
									                 AlexJoined on 04-16-2007Bath & Cardiff, UKPosts 2,990 |
										    Re: Apple express, better sound with a DA converter, but which one?
										    Before adding a DAC, the first important steps are:
Completely disable the iTunes 'Sound Enhancer' (in the Playback tab in Preferences)Completely disable the iTunes EqualiserTry to avoid using the iTunes volume control - the AirPort Express is only 16bit so doesn't take kindly to having it's signal scaled for volume controlTry to avoid using the iTunes 'Sound Check' for anything other than shuffle mode and/or parties (where it's an absolute lifesaver!) Then look at a DAC. On a budget, the Cambridge Audio DAC Magic is a great piece of kit...  Weekly top artists:
										     Alex:
 Thanks Alex!   I'll make sure to check all those. I'm on a max 1000 euro budget on this one, I was looking at different options at different price ends, at the top end the Benchmark DAC, and at the lower end the one you recommended, the DAC magic from CA. I'm pretty familiar with the CA products, and I can have a further 30% off on them, so this might be the route for me? At roughly 200 euros after discount, it must be a steal? -Andreas
									                 david coyne
 Joined on 04-17-2007Sydney, AustraliaPosts 165 |
										    Hi Andreas I to have purchased a Cambridge Audio DAC. I did however hardwire my mac mini through beoport and to my beocentre 2. The DAC made a significant difference, though i still can tell the difference listening to a high bit rate mp3 and CD. Certainly the DAC does make a difference though, even to NRADIO, which is almost bearable now! Generally im still disappointed with the sound of some mp3's but i cant always get the tracks i want in CD format or lossless format- eg a DJ track that is only around in 320 mp3. Good luck with your purchase, I'm it will make a big difference Best Wishes David BV8-40, BC6-26, BC2, Beolab 9's, Beogram 7000, Beogram 9500, Beoport, Beotalk 1200, Beocom 6000, Beolit 1000, 800, 700, 600, 400 |  |
									                 majandJoined on 02-26-2008HelsinkiPosts 72 |
										    Terve Andreas,   I have an iMac, CA DAC, Ouverture and BL4000's, and for me the DAC was a big improvement. I have a wire from DAC to Ouverture though. This is not a scientific opinion, i've not tested w/wo DAC, but to me, eg. YLE Areena stream through browser sounds pretty awesome.   Pekka |  |
										    Is this for use with your BeoLab 5s? If so I would definitely suggest the Benchmark DAC, which really is absolutely excellent.   Of course the most ideal route to go down would be digital out of the Airport straight into the BeoLab 5s, which will sound quite a bit better, but this isn't always possible with more complicated setups...  Weekly top artists:
									                 Puncher
 Joined on 03-27-2007Nr. Durham, NE England.Posts 9,588 |
										     DoubleU:
 Doesn't this review recommend using a DAC other than the one built into Squeezebox? Generally speaking, you aren't learning much if your lips are moving. |  |
									                 beopaulJoined on 07-28-2007USAPosts 68 |
										    Airport Express digital out has been said to have sloppy timing, which may cause some otherwise good D/A converters to have synching issues.  You'll need to watch out for this as you make your choice.  I myself intend to get a converter, but haven't gotten around to it yet.   -- Paul |  |
									                 DoubleUJoined on 05-09-2007Posts 866 |
										     Puncher:
 DoubleU:
 Not if your on a max 1000 euro budget.
 As far I see it, the review stated that the Touch’s DAC
performs well, comparable to listening to other DAC’s  if your on a budget, but is no match for the
very expensive DAC’s.   Using the Touch's analog outputs (and, therefore, DACs) was
another story. The sound was clearly inferior to what I heard via the
processing and D/A in the Classé and Meridian processors, but good enough that
I could distinguish mashed low-bit-rate streaming from the better stuff, and
even an HD download from a 16/44.1 download. It was just that the quality
levels of all recordings were shifted down a notch or two by the
Touch's analog outputs. The Touch's analog outputs were still eminently
listenable, if not fully revealing of the source materials, and comparable to
listening via the analog outputs of the Oppo BDP-83. |  |
									                 tournedosJoined on 12-08-2007FinlandPosts 5,808 |
										     Puncher:
 DoubleU:
 Doesn't this review recommend using a DAC other than the one built into Squeezebox?![Confused]()
 Dunno
 how the Squeezeboxes perform now that Logitech bean counters have had a
 go at them, but the original "Classics" designed by Slim Devices
apparently were excellent. The review says that it was't quite at the
level of high-end DACs - in the context of this thread, I still read
that as "a lot better than Express"! Just today I talked with a
friend that raved about his Squeezeboxes. He has (among others) an older
 box, Duet I guess, which has a two-way remote with a display. At some
point, a software update added the ability to listen to music with the remote (it has a headphone jack). Sounds like a developing platform... |  |
										     Alex:
 Yeah that would be the best option, but since my Beolab 5's can't sync, it's out of the question...  -Andreas
									                 Pauliander
 Joined on 06-14-2010BelgiumPosts 34 |
										    Hello Bayerische, Two options you should definitely also consider are: 1/ Apogee Mini-DAC: price/quality very good, probably nicer sound than the Benchmark 2/ Bel Canto DAC: by far the best. The DAC 3 is a reference high end DAC but expensive. But I know that Bel Canto recently also released a series of less expensive DAC's. I would strongly recommand you to check out these ones if to be used with BL 5... Greetz, Paul   BC2 DAB, Lab 1, Lab Penta, beo4, beocord 1101. |  |
									                 Sigmund
 Joined on 06-20-2007NorwayPosts 46 |
										    First, go get a DAC! It makes a huge difference. In my case it comes in between Airport Express and BeoSound Ouverture. Since the external DAC is better than Ouverture's own, I find the CDs improve by playing them on the Mac instead of directly on the Ouverture. Make sure it is easy to operate, though. I bought a Stello DA100 from April Design and would probably not have chosen the same again. The sound is superb. Problem is it gets hot, so hot that I don't want to have it turned on at all times. There is no standby power saving mode. Listening to music means turn on the Ouverture, turn on the DAC, turn on the Mac and choose music. That's awkward compared to B&O's easy and remote-controlled environment. If you can find a DAC that is a little easier to control or that has a decent standby modus, that's a real advantage. Sigmund   |  |
						     Page 1 of 1 (14 items)  |
