Latest post 10-20-2010 11:51 AM by elephant. 5 replies.
Page 1 of 1 (6 items)
  • 10-17-2010 2:46 PM
    • Alias
    • Top 500 Contributor
    • Joined on 04-23-2008
    • Posts 90
    How to set up Beoport for Mac
    Hi
    I have some trouble with the Beoport. I got the Beoport PC and connected it with my Mac Snowleopard.
    I also downloaded the software.
    But I can't control iTunes. How is it possible? I have a Beo4 with Joystick and the IR eye with no lables. I think I wired it corretly becuase the red light is on. I also set up A.Opt 2.
    But I can't control iTunes. What do I have to do?
    Thank you!
  • 10-18-2010 6:07 AM In reply to
    Re: How to set up Beoport for Mac
    It all depends upon what you mean by "control".
    BMLINK allows you to use [N.Music] and [N.Radio] commands from your Beo4 to "talk" to iTunes to:
    a) play music from your iTunes collection, skip tracks, and switch between blue, yellow, red etc modes
    b) play music from internet radio stations you have defined in iTunes under a playlist of "N.RADIO"
    So was BMLink the software you downloaded ?
    And what type of Mac are you using (Macbook, MacMini, etc) ?
    And have you plugged the BeoPort into (1) the audio headphone jack and (2) the USB port ?
    If you want more "control" than what I just described then you probably should take a look at Philippe's LinkPlayer ....
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 10-18-2010 2:10 PM In reply to
    • Alias
    • Posts 90
    I tried with an Windows PC with BeoPlayer. Everything works fine. But with my Mac I can't control iTunes. (Skip tracks, etc.
    I have an MacPro with Snow Leopard 10.6.4. I connected the Beoport to mac via USB. The audio is connected via Jack not from headphone. It goes into Audio In in Beoport. I also connected the IR Eye. It is also connected to the mains. ;-)
    I downloaded the newest version of BMLink.
    What is Philippe's LinkPlayer?
    Thank you
  • 10-18-2010 2:32 PM In reply to
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    It works fine for me
    I also have snow leopard
    I'm ready for something new that I actually want to buy!
  • 10-18-2010 2:58 PM In reply to
    • Alias
    • Posts 90
    Now it works! I only had to restart BeoPort now everything works!
    Thank you!
  • 10-20-2010 11:51 AM In reply to
    Now that is working perhaps you don't need this temptation :)
    Alias:
    http://web.me.com/philrobin/LinkPlayer/Linkplayer.html
    search for linkplayer on these forums - you will find lots of threads about it
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
